  • Replies 14.2k
for anyone that likes their high octane super large baffeled and gated sump extensions and is thinking about buying one sometime soon, perhaps hold off on buying one as mine is apparently weeping oil =\
How so and from where?
boostworx are looking into it now (as they sold it to me/buit and installed it), but yeah, shaun is once again going above and beyond!!!
from the description he gave me it just seems to be from the metal itself, its coming threw the walls etc, nothing to do with welding etc droplets of oil just appear on the outside of the sump =\
yeah, i just dropped it back to them because run in had finished and there were other oil leaks (when i first got it back there was a leak from the head and power steering, then a leak from the oil relocation kit) and now this XD
seems very wrong, apparently it only happens when the it heats up if its just sitting there nothing much will happen... so its only a problem if i drive it =(
ah well... just means another week+ delay on getting my car back, but it'll be fixed and thats the important part
My thoughts too however they test each one with a coloured dye after they are manufactured, surely this issue would come up then?
Or so they say. The first series of VT's has a similar problem with the cast alloy transmission pans weaping through the casting. Problem only arose after the car had be driven for a while (constant heating up and cooling down). Therefore if it is a porys casting then it would only show up more so after install and driving than in a simple bench top penetrative dye test.
Least you can actually drive it now though aye :)
On another note, I'm back in the Nissan product :D swapped my RX7 for a 180 last night lol
Yeah not quite...
donkeys haven't cleared it on their systems so i cant renew my rego
losers...
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
    • Well, yeah. But I just expect everything other than my car to feel like a bucket of shit anyway. I still miss my Alfa 116 so much though. You could run over a 20c piece and tell whether it was heads or tails.
