If you want to bring it up to my place on Wednesday night i'll do it for you, and i have the right tools LOL.
If you don't have the right shape drifts you will find it very had to get the bearing keepers back in.
Keen to take you up on this also Dale, will PM ya when I acquire funds lol.
  • Replies 14.2k
Anyone know any good gym equipment whole salers in Adelaide that do decent prices on things like bench, bench bar, adj dumbells, etc etc.
Not interested in a cable system as I prefure free weights, loss of license means no way to get to a gym so I'll bring a gym home LOL
There's some mob on Port Road, Hindmarsh who I can't recall their name. They have decent equipment. Just up from the Entertainment Centre if you're willing to suss it out.
I don't get out to a gym much anymore, so I have my own home gym that gets used more than any gym franchise I once joined. I don't have the full range of equipment like a proper gym ... but at least I don't have to wait to use my home equipment.
What headgasket should i run on my rb25det? Was quoting a rough estimate on a ACL Metal Head Gasket from turbo tune fr about 250 300, i think it was and also is it worth geting the ARP head bolts?
depends on the application? Making enough power to warrant a steel head hasket and stronger bolts?
Just do it, for a few dollars now, you won't regret it later. I'm doing mine soon, including a port/polish on the head and I'll be going the same route (Metal HG and ARP head studs)
yeah i have to have my head inspected for cracks and shit, so also thinking a port and polish.
Its actually in a VL for now haha
<br />There's some mob on Port Road, Hindmarsh who I can't recall their name. They have decent equipment. Just up from the Entertainment Centre if you're willing to suss it out. <br /><br />I don't get out to a gym much anymore, so I have my own home gym that gets used more than any gym franchise I once joined. I don't have the full range of equipment like a proper gym ... but at least I don't have to wait to use my home equipment. <br /><br /><img src="http://www.skylinesaustralia.com/forums/style_emoticons/default/thumbsup.gif" style="vertical-align:middle" emoid=":)" border="0" alt="thumbsup.gif" /><br />
<br /><br /><br />
Cheers Rubz, I'll go for a drive tonight and see if I can see what your talking about.
I'm down with you on that I HATE waiting for equipment at the gym. I'm really keen on a bench and free weights, adjustable dumbell and bench bar and you can basically work out every part of your body from that and the fact its free weight the surrounding muscles get a workout to stabalize the weights. Cable sh!t doesn't do it for me.
Don't forget guys that if you if you are going to run metal head gaskets you will need to prep both the head and block mating surfaces to the correct finish. If you don't then there is a fair chance that they will leak.
Now you have to ask yourself how you are going to prep the block with the pistons in place.
Also don't forget that if you are going to change to ARP studs then you will need to torque plate hone the bores as you will be using greater torque settings and the bore will be more deformed. This is the same story for main studs in that you will need to line bore the mains.
So i guess the moral of the story is that if you are going to do a rebuild it a perfect opportunity to change to MLS head gasket and ARP studs, but other than with a rebuild it's not the ideal time to change.
There are many flaws in that argument Steve, but surely even you recognise that 'God' is a word that men created to describe events that they couldn't understand. For the above statement to hold true God would have to be measurable like light and heat.
Also you can watch evolution at work by studying a virus (although there is some debate as to whether viruses can be considered a form of life or something that exists at the edge of life).
Last time I checked Dave, it was the other way around.
I prefer to believe that I was created in the image of God rather than have evolved from a Baboon....although when I wake up some mornings, the mirror tells me a different story :)
Weezy, the place that Roo is referring to doesn't make good quality commercial stuff....unless times have changed.
I had some commercial grade equipment made up many many years ago at a place further west of the that place (SA Gym Equipment 456 Port Road, Hindmarsh).
I'm not sure if they are still there (probably not) but unlike most places, this mob used cast pulleys (not plastic) with bearings (not nylon bushes) and heavier grade cable. They had a wide range of olympic bars & benches, power racks and smith machines with ball brgs rather than nylon bushes.
They'd custom make anything you wanted.
You're welcome to check out my set up if you ever need to get ideas.
Spot on Dale, unlike a composition style head gasket, metal shims are nowhere near as forgiving.
As for torque plates, I've measued bores on some overbored blocks from underneath with an internal micrometer after a head was bolted on to find an oval bore with a discrepancy of as much as .010" (.025mm).....and peeps wonder why some recon engines burn more oil than worn out ones, lol.
Line boring mains isn't always necessary though, but you should still torque the main caps with brgs installed (but crank removed) and check for clearance, end float and brg crush before final assembly.
My only problem is my pocket isn't oozing with disposiable money - I'm sure getting something custom made etc would cost a pretty penny,
Having said that I know this stuff is expensive but you can go over board, so I don't mind forking out coin to a degree lol
PM me some photos of your setup if you don't mind Pete? I'll have to swing passed there and have a look.
Edited by Weezy
I've only got one a bit weeks left of license left rofl,
So you think SA Gym Equipment are the way to go? or are they the ones that build poor quality?
SA Gym Equipment are the good guys....that's where I got my gear from.
But like I said, I don't think they're there anymore......not sure if they've closed for good or just moved......check the above address first.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
