  • Replies 14.2k
The amount they had patrolling the cruise, meanwhile RCK cruise would have been on... We would have been free to rob a bank. Surley every cop would have been tied up with some people 'reving their engines and congrigating in a big group' damn youth of today :)
I wasnt hasseled but amazed at the amount of police they've dedicated to something like this.
They need to rearrange their prioities
What, like the Police band they had playing in the mall all arvo? Earning their keep :)
I go on the bigger NS cruises... (Christmas Charity, BSM etc.)
So do you Ruby, Ive seen you there :)
I show up to the meet spot for the chat on the rare occasion (for other business) ... but I don't roll with them :thumbsup:
Don't forget guys that if you if you are going to run metal head gaskets you will need to prep both the head and block mating surfaces to the correct finish. If you don't then there is a fair chance that they will leak.
Now you have to ask yourself how you are going to prep the block with the pistons in place.
Also don't forget that if you are going to change to ARP studs then you will need to torque plate hone the bores as you will be using greater torque settings and the bore will be more deformed. This is the same story for main studs in that you will need to line bore the mains.
So i guess the moral of the story is that if you are going to do a rebuild it a perfect opportunity to change to MLS head gasket and ARP studs, but other than with a rebuild it's not the ideal time to change.
So im better of just going a standard genuine headgasket then?
Also were is the best place to order parts, im changing headgasket and sending head of to be checked out. Also doing a 100ks service while its off the road.
What place to you guys order parts from?
Cheers for everyones help.
Like I said, a composition style head gasket is more forgiving but even one of those won't help you if you don't resolve why it blew in the 1st place.
Don't just throw the old one away if your doing the job yourself cause it may give you a clue......I'd be showing the head and gasket to a mechanic once it's off.
Has anyone here ever had any experience with aftermarket LSD's in a GTR?
Got one in mine, will do some digging and find out what it is and let you know mate, pretty nice to drive with.
Well actually had a guy having a REALLY close look at mine on sunday while i was out with Kristian. Quickly looked over his N1, but paid real attention to mine like: looking for engine number, checking rego sticker, compliance tag and a few other things. Meanwhile this way while it was parked and locked up on a primary school oval :D
I have a Nismo 2-way in my car.
Which is why I don't attend them :D
Got to be careful on those cruises when ya rolling on 17's and 4WD spec ride height, cops will be all over that shit!
Fkn LOL!
Also, whats with the skyline's these days? They are all over the hoon stories!
First it was a silver skyline on Rundle,
now its a white skyline, with a boost controller.
On Monday, my mum was reading the paper, and pointed the story out to me, asking me wether i would have a boost controller in the car im probably going to buy. My reply was "yes, why's that?", to which i got the most blunt, shocked, and 'oh my gosh' look on her face.
I didn't tell her that it's got a pod filter, that would send her bonkers..
Fkn LOL!
haha, good one.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
