  • Replies 14.2k
gettin pretty desperate for stock 33 gtr suspension....can anyone point me in the right direction ? Need to borrow it just for an ID inspection (and yes posted it up in the "wanted to borrow" thread, with no luck..)
Hitup Sinergy Motorsport - See if they will lend you a set and or go into Japanese Import Spares - from memory they do hire out items too. Of course, you break it you buy it haha
around 4 months ago; we had to twist koji's arm to lend us a part for 24 hours. Put some dollars under his nose for them to hold on to and he ended up letting us have it, but he was reluctant to as he didnt want to get in strife from his manager
may have a different system in place now though
Pre sale is Friday to Monday on ticketek website.
You need to be a member of ticketek which is free to do online.
They went on sale at 12 noon today and the servers were flooded. Finally got through and at 12:30 gold seating was only in singles and silver seating had to be refreshed about 20 times before they let me go through but standing was all good.
$150 a ticket though but will be very worth it!!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
