  • Replies 14.2k
does anyone know the thread how to solder your headlights (R33) so that when you use high beams the low beams stay on
i cant think of the search criteria, i was once upon a time subscribed to the thread but lost all my subscriptions by accident (my own fault :))
if its just 12v and under the amperage to blow the fuse, u should be able to wire a positive feed in parallel from the positive in on the high beams to the low beam (providing they run at the same voltage and theres no step down - I wouldn't think so but its best to check otherwise u could overload either a fuse or blow the globe...)
low beams are already grounded so I should think it'd just be one single wire you'd need
-D
no, do tell
Gunmetal 4 Door, 5 Speed, FMIC, Exhaust, Dump Pipe, Clutch, Rims, New Bushes, KYB Shocks, Custom springs, (not cut), New aircon ($2k worth), 550hp fuel pump.
For about 1/3 of what I paid for mine.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
