People look like they have aids if they loose too much weight and don't replace it with muscle. I've lost 20kg in the passed year along with weight training so I have no idea how much actual fat i've lsot but as a total on the scales, lost 20kg. Since loosing my license I have had to quit my gym membership and look at alternatives at home, which is a massive struggle.
Ride a mountain bike to the gym ... there's your cardio workout sorted! :D
  • Replies 14.2k
does anyone know if there is an english copy of tourqe settings for bolts on/around the rear knuckle, control arms etc on a 33? Might actually have a go at replacing mine this weekend and don't want shit vibrating loose.
Cheers.
What do you eat for meals like dinner etc?
With the program you replace two meals a day with the shakes and then for your meal you have 200g of protein (Fish, Chicken, Lean beef, lamb or pork) with salad or veg.
There are some fruits and veg that you aren't allow and some which you are restricted to a certain amount of per day. No fruit juice, breads, rice, pasta, potatos, pumpkin, corn (Basically no carbs that aren't in the shakes) your allowed salad any time and there are some soups that you can make that you are allowed any time.
Oh and you have to drink 2-3 litres of water per day.
bet you could smash a big mac now eh Dale
No not really, don't really miss any food now (Except for bread and potatos) but in the first week you would be correct.
I've slowed down with the weight loss now, first week i lost 6.5kg's but last week i only lost 1.6kg's.
Oh and i have done 0 exercise at this stage, they say for the first month not to while your body get used to the reduced calorie intake.
more part availability, so i wont get teased of sliding the family shopping car etc etc
Always wondered why you picked the 31, it may be cheaper initially but an S series chassis is cheaper in the long run with the assload of parts available for cheap
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
