Not sure if non-FBers can see this or not, but check this out. Loved it.
http://www.facebook.com/home.php#!/vid...v=1218044052737
Yeah seen that plenty of times. Funny as. Reminds me of my Grandfather. He was a boxer in WW2 and he could still hit em hard before he died at 82yo.
  • Replies 14.2k
Troy i used to have BFG sports 235x45x17 they were a decent tyre
then i heard they were stopping that one or something cant remember this was 3 years ago
yeah old man pwned that noob
EDIT
are these sort of what you were thinking
EDIT
hahahah these are semi's
thanks matty, definitely good to be home. never been OS before, bit of culture shock for the first couple of days, but when you get used to the 32+ degrees and stupidly close to 100% humidity, its alright. stayed for 10 nights, just enough time to make me enjoy coming home.
yeah and more $$$
f**k it, ill keep sliding the 31, dont care what others say.
eventually it will more than likely come to an end, THEN ill worry about another set up.
Kye, organise a private day!
i cant say iv ever driven a CA, its just the thought of a 4 cyl makes me feel all dirty
Think you need to come for a drive in my car as well Craig, nothing dirty about a 4 cylinder champ....
ANYONE HERE WORK AT THE MINES OR RIGS?
Getting close to finishing my studies and need some hook ups.
Cheers
if i still worked at BHP I'd have been able to put u in contact with a HR manager... ;\
best bet is to get a copy of any certifications you have (such as forklift licences, heavy vehicle licences, tradie stuff) and forward it to the HR manager @ 55 Grenfell St, Adelaide, 5000 and make sure your cover letter is 100% awesome enough that they put u on file. They will eventually be turning OD into an open cut mine which will eventually be very labour intensive, I just don't know when its going to happen.
Other thing is, there are a few other natural resource companies that are based in SA like petratherm, they are small outfits now but just about all of them are projecting exponential growth once their mines/taps become operational, so I'd also be doing some research about the different companies around here. Some are based around ores but there are also LNG and thermal/solar/wind to consider too
Whats your trade?
-D
What sorta stuff you interested in Kye???
Hey mate, I'd really really like to get into mudlogging on a rig but I'm not overly fussed.
I'll be qualified in pretty much geoscience areas so I'll have to work around the geologists mainly.
Whats your trade?
-D
hey bud, I'll be qualified in mining exploration and diploma in geoscience.
I've got first hand information through an industry orientation lesson about a few places (mainly rig based) and all my info regarding PIRSA.
Also my girlfriends dad worked for Rio pretty high up too but I'm trying to attack this job hunting every which way I can through as many different contact as possible! Due to this stupid tax purposal, a lot of natural reasource companies have slow production till it's all sorted so getting in can take some time right now.
I've got petratherm on my list a long with beach petrolium. Hot rocks seem to be the way of the future but at the moment their only small areas in a huge industry at the moment.
Going to be busting out the resumes everywhere just seeing if anyones got direct contact so I can bypass all the crap along the way and hopfully snake a few people :)
cheers
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
