  • Replies 14.2k
Dear **************,
your a f**kn puff the crank sold for less ,you are a week little boy hid,n behind your computer , do the world a favour and f**k off
- 6321kris 320523152698.jpgEnd time:06-May-10 19:09:29 AESTSeller:
Listing Status:This message was sent while the listing was closed.
I've copied the email to Ebay. See what they do with the guy now. My response to him was that if he was going to send abusive emails, he should at least learn grammar and some spelling first. :)
Ah geez, if only this wank knew who he was abusing. The difference between you Ruby and a keyboard warrior, is Ruby will travel interstate to knock on your door!
Thankfully I hadn't paid the $96 for it ... so there is no real loss. I had thought about a QLD holiday, if I HAD paid the $96. But right now I'm just amused at how 'fragile' this guy's temper is. Negative feedback obviously is rated up there with declaring war for this guy. :) I'll play nice and go thru the ebay avenues to get him a slap on the wrist for whatever its worth.
Unfortunately for you, I can't see ebay doing FA about it!
Yeah I know. Like I said, no money was lost in the end. Which is why I'll leave it at ebay. If they take it no further I'm not going to sook about it :(
If anyone wants a cheap GPS unit, Super Cheap (at Port Adelaide, not sure about the other stores) are selling the Nuvi 260 for $49!!!. Cash Cons are still flogging off these for $175 second hand :)
I paid like $300 for mine (twice ... yes I had two thanks for thieves) some 18 months ago. They're a good unit, so I've bought another one ;)
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
