  • Replies 14.2k
i think its time for some maintenance free batteries for the rig, they're not liking the cold weather (or me LOL)
yeah im getting a new battery when ive got the cash
just tryin to put cash aside for my passport and other associated things for Japan in a few months
Here's what i started with
anyone seen any cars for around 5k give or take a grand if you like, that would be a cool little boonga spec car for a new daily?
i had my heart set on another car but when i checked it out the second time, i noticed a few things i didnt like so im back on the hunt.
thought about building something cheap but i donno
couple 4wd sr20 powered gtir pulsars on carsales atm for around that price :blink:
-D
Dohmar, i thought about buying a gtr but i just wont drive it thats why im looking for something cheap as i can only drive 2-3 days a week and soon it will be 1 week of the month :blink:
also, i dont like SR's lol but might have a look at them
Edited by Import S13
Far out Luke!! Nice work. You doing that yourself? I wouldnt have a clue what to do after getting the valley covers off lol.
Yeah got Simon helping me out but it's getting there. Sending the head off to Rhemac tomorrow for a port/polish and getting them to drop the Poncams in while they are at it. Then I'll pick it up, get Simon to bolt the head back on with the new ARP head studs and head gasket, complete with the Tomei oil restrictor. Then it's up to me to bolt on the rest. Oh happy days!!!
Looking at the bores however, all seems well, no pitting on the pistons from detonation or the like so the bottom end seems in pretty good nick thankfully! Just need to get a retune after it's all back together, then back to the track!
Yeah, there are a few hoses I'm looking at that I'll replace while I'm there. The motor is in very good condition really, no pitting on the pistons, no scores in the bore and still has the cross hatching. Looks like it should be sweet for some time to come :blink:
I should hope so if your tuner did a good job lol
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
