  • Replies 14.2k
i think its time for some maintenance free batteries for the rig, they're not liking the cold weather (or me LOL)
yeah im getting a new battery when ive got the cash
just tryin to put cash aside for my passport and other associated things for Japan in a few months
Here's what i started with
anyone seen any cars for around 5k give or take a grand if you like, that would be a cool little boonga spec car for a new daily?
i had my heart set on another car but when i checked it out the second time, i noticed a few things i didnt like so im back on the hunt.
thought about building something cheap but i donno
couple 4wd sr20 powered gtir pulsars on carsales atm for around that price :blink:
-D
Dohmar, i thought about buying a gtr but i just wont drive it thats why im looking for something cheap as i can only drive 2-3 days a week and soon it will be 1 week of the month :blink:
also, i dont like SR's lol but might have a look at them
Edited by Import S13
Far out Luke!! Nice work. You doing that yourself? I wouldnt have a clue what to do after getting the valley covers off lol.
Yeah got Simon helping me out but it's getting there. Sending the head off to Rhemac tomorrow for a port/polish and getting them to drop the Poncams in while they are at it. Then I'll pick it up, get Simon to bolt the head back on with the new ARP head studs and head gasket, complete with the Tomei oil restrictor. Then it's up to me to bolt on the rest. Oh happy days!!!
Looking at the bores however, all seems well, no pitting on the pistons from detonation or the like so the bottom end seems in pretty good nick thankfully! Just need to get a retune after it's all back together, then back to the track!
Yeah, there are a few hoses I'm looking at that I'll replace while I'm there. The motor is in very good condition really, no pitting on the pistons, no scores in the bore and still has the cross hatching. Looks like it should be sweet for some time to come :blink:
I should hope so if your tuner did a good job lol
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
