Its 14psi man, and if it weren't the engine would lean out and go BANG! as I only had standard injectors. And the standard boost gauge represents 14psi where it hits and sits all day everyday
fixed
  • Replies 14.2k
Can someone help me out with a paypal payment? Its only $50, but its for a part I need in the post asap. Will get the $50 to you asap.
Long story, but I've close my bank account that I use to have my paypal linked with. Now I have no paypal set up properly.
PM me if you can help ... thanks :P
LoL I must be the first person to drop out of the Skyline club,, and let me tell ya they pulled my access to the forum area within min. of the email.
without even a return email to me = Pretty Lame
now I feel like the rejected redheaded stepchild...hahaha oh well
No you're not the first Troy. Your membership had lapsed and I sent you a PM regarding this, and you replied in turn advising you would not be renewing. Given your membership had lapsed and you advised not renewing, I informed Andrew to remove your tag (along with some others who have not renewed yet).
I don't see the problem Troy.
Your departure has been discussed with Shane and Pete, and we will be in contact shortly to discuss your continued involvement/discussion at some level with the club, and welcome your returning to the club in the near future.
:P
:P
damn.... I wanted to be first at something,,lol
guess I better practice up on my drinking skills now. for the next overnight car shows
I like stiring Ruby up..lol he gets so official..lol
Its 14psi man, and if it weren't my engine would lean out and go BANG! as I only have standard injectors. And the standard boost gauge represents 14psi where it hits and sits all day everyday
the only thing that goes bang over 14 psi are ceramic turbine wheels
you'd make up to the 270-280 mark with std injectors at 99.9% duty cycle - only if you pushed it harder would it make a diff
guessing u had some kind of steel compressor turbos and the tuner set it to a good safe level...
-D
Whoze to say I have standard turbos in there Dohmar, not to mention if they are standard - whose to say they havn't been hifloed in any case if it did go over 14psi the motor would lean out and I'll be melting pistons lol
Congratulations, welcome to the year 2005 - you may now somewhat multi-task. :P
I'm joking(kind of)! I'm going to grab me an iPhone 4 as soon as its release, cant wait :angry:
I cant access all features of OS4 because I only have the 3G (as opposed to 3GS) but it still looks pretty, and works better.
I have a Nokia! Can I join in? :angry:
Cam has an iPod ... is he closer to being special than I am? :P
lol, I dont know (not saying you) why people get so uptight about paying out this that or the other, its a phone for crying out loud lol. Its only natural people have different tastes and preferences
Home screen is slightly updated, glass look thing down the botttom now and a few different icons
you missed my point
simply boosting past 14 psi is not a guarantee that it'll lean out - have heard of many people running n1 turbos on a 26 and having 18psi boost and getting a similar power figure to you - not sure how u manage that, as the most I ever got with 14psi boost was 210kw on stock gtr turbos
-D
When I replaced my iPaq PDA, I wanted an iPhone ... but the price just wasn't right at the time. Two of the guys in the office have them, and they complain all the time about something wrong with them. I figured I'd just get a 'normal' (read: boring) phone for now ... altho my Nokia does have touch screen for easy use and internet access (3G) albeit slow. :P
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
