Ahh I more meant the stuff before ceramic coating. I know morrie at horsepower in a box can get stuff ceramically coated too but hes on the other side of town
-D
It won't look too much different, I'd get pics but I won't have a chance before I head off to Melbourne tomorrow, they go to the coaters on Monday. Maybe when I get back on Sunday
  • Replies 14.2k
For all you trance fans...
Armin Only 2010 world tour has been confirmed! 9 hour live set from Armin Van Buuren - later this year.
And Gods Kitchen in October!
What a f**king epic win.
awesome news man.....
