  • Replies 14.2k
QUOTE (heslo @ 25 Jun 2010, 11:39 AM)
True, but I'd rather be home in bed and warm than in a hot blonde. Thinking of heading out but not sure if I want to brave the weather
Fixed for Krishy
Much better I say :)
f**k YES
that is all
yeah with ya on it matty
i dont know a thing about fj's but i dont mind the dr30 itself.
wonder if they might be worth something decent later on? its a hard choice cause i want something to track aswell but i can just buy something else later on to track.
might see if niko from smooth will come down and have a look at it....
giving myself till sunday to make up my mind. feel free to talk me into it lol.
I just went to an invites-only Toyota sale thing at that huge Toyota dealership in the City... I just wanted to look at a used car but had to be paired with a sales guy that pretty much ended each conversation with some way of trying to sell me the car tonight. :)
should i buy a dr30 (fj20)?
can get one in mint cond for 6k with some decent mods and pretty low km's
Might be a little bit biased but yerp! You won't regret it, strong as all hell, brake upgrades are easy...Only thing to remember is parts are hard/expensive to obtain and its not like a s13 or R3x series skyline, you can't just get parts for them from anywhere unfortunatly....But very rewarding cars!! Just need a lower seating position in them...
Fut yeah for the dr!!!
in other news, collected the keys to our new home this arvo :)
can you beleive the stingy renters that where in the before (whom we kicked out)
stole all the f**king light bulbs!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
also, is anyone on here in the fencing business or know of anyone?
cheers
in other news, collected the keys to our new home this arvo :laugh:
cheers
f**king :)
cheers
Grats buddy!!!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
