  • Replies 14.2k
was a slow day in the office today...
we found a vhs tape and put it to good use
That was only stage 1. I was too busy helping with stage 2 and 3 to be bothered taking pictures
-D
Hard at work there Dohmar?
LOL, I work in a department store - mostly when its closed, we sometimes get up to a bit of mischief :blush: :blush:
ive got $100 for the whole day -__________________________________________________________________________-
once i get petrol and pay cams fee i wont be able to afford tyre changes
unless someone wants to buy some 33 parts ?
rear 5 stud hubs and knuckles ??
r33 console??
abs brake master??
Man, you've already paid $160 to enter man. What a waste of cash if you don't just borrow a little bit extra! FFFS
i didnt borrow that , apparently its part of my birthday present o.O
after my dad saw my tyres are on canvas hence not driving the thing , he went ape shit at me lol so HOPEFULLY they wanna chip in more
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
