thanks steve, pretty much all my gear is on now, just waiting on glenn to be ready to order his bride rail and ill order mine then ready.
so realistically mid/late august should suit everyone. will you be out next time steve?
  • Replies 14.2k
yo weezedog!
i need to give u my afm so u can give it to mitch sat so he can test it out..
when can i drop it round? or leave it in ya letter box?
I'll be home around 10:30pm tonight Age, Don't put it in the letter box, a boongs live on my street and it'll go ciao b) it might get wet.
Pop round tonight after 10:30 and I'll be home man!
+1 on grip day. My cars built for skids but i dont give a f**k... I just wna get out there and thrash the pants off it LOL
Edited by Weezy
Should be late Aug early Sept... And Steve better be coming!
just going to throw it out there....
how many people would be keen for a private track day? (drifting of course)
not going to organise anything till i get my roster sorted so i know when im back on shore but would like to know the numbers from here as ill have a few mates keen.
Just remember skynats is early september too, august works good for me :D
KEEN!
Btw; printed off my SAU:SA Application form tonight, all filled in and signed so I'll pop that in the post tomorrow morning probably and I'll receive an email reguarding account details to drop the funds into no doubt? I went to submit it via email but the adobe system declined it? fpos haha
$240 sounds decent including lunch haha
Edited by Weezy
wilko i got ya number man so as soon as this is up ill let u know.. of course if its sau-sa first then u will have to sign up :)
wouldnt mind getting my car up agianst yours again.. this time i wont find out half way through yours is built... hahaha
mine will be fully built now too :D
wilko i got ya number man so as soon as this is up ill let u know.. of course if its sau-sa first then u will have to sign up ;)
mine will be fully built now too :)
adriano maaaaate.. so your behind this?...
hahaha yes i like to keep a few things up my sleve
cool man yeah first time i been on in a while been flat out so never got to tell ya the build specs
so who is doing yours? what you doing?
i got my fingers crossed for early september as I'm doing my solar accreditation early august... :D
how'd that plenum go by the way?
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
