  • Replies 14.2k
NO RESERVE AUCTION,WILL BE SOLD TO THE HIGHEST BIDDER - 15,000 sale priceGTR_R33.doc
1997 NISSAN SKYLINE R33 GTR SERIES II
2.6 LITRE TWIN TURBO
REGO TILL 26-08-2010
CLEAN VEHICLE
ALARM WITH KEYLESS ENTRY
HKS AIR FILTERS
TURBO TIMER
SOME WEAR ON DRIVERS SEAT
VEHICLE IS LOCATED IN WETHERILL PARK SYDNEY
see attached:GTR_R33.doc
No, I want !
Selling the r32 sedan rb26dett "track car" for what I bought it for. See sig.
Keeping this R33 GTR, and will do-up slowly
Got all parts for rb26 engine build, cant wait to pick her up!
15g plus pickup costs (fly/drive) and rego.
seems a top price
Ive requested a list of the owners "knowledge" of the car.
is that the wheel that James is running, cause they only go up to 18's unfortunately.
What colour were you thinking?
I'm running CR KAIs in the biggest size they come. You are more than welcome to try them if you like. James has XD9s that come in 18x10. Mine are 18x9.5
Yeah sorting out some long standing issues, needs another dyno run to check the tune. But its putting out around 350 hp at the wheels.
Just sorting out the attessa system on it at the moment.
Hows yours going?
Sitting in my shed with no engine lol
Remember that RB25 I imported from Japan ages ago? I'm in the process of putting that in.
Good luck sorting out the 4WD!
would really like someone to poop up and be like "hey i have an engine crane u can borrow"
I've got an engine crane, but I'm using it for a job tomorrow. When did you need it and for how long. Its not mine, so I'll have to ask a mate to third party its use.
sorry
my old man is using 3 atm. lol, 2 engine cranes and 1 engine run-in machine
if i coulda I woulda grabbed one months ago. perhaps hire one from Kennards Hire? did that over xmas to help mate take out/rebuilt a 543cc suzuki
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
