  • Replies 14.2k
Nismo Super Coppermix.
ah thats the name.
cheers mate.
will get all fluids done with the timing belt service, might look for clutch prices (ie ebay. lol)
realized Ive got way more than listed previous page, 30row oil cooler, etc etc. awesome
nismo super sports version for $1700ish, NISMO Super Copper Mix Twin Clutch Kit Skyline GTR BCNR33 with RB26DETT engine.
(Sports clutch disk(Copper mix), Sports clutch cover, Light flywheel, Release bearing(Nissan parts), Nismo no: 3000S-RSR35-E
same seller does me discount (jps trading) so could grab this option when needed. ta for the advice. needs to be light as a feather
Rant,
Coming home from a mates place tonight. Coming onto north east rd from Kelly street. Look left look right twice and go. According to the policeman this wasnt enough and i didnt come to a complete stop at the stop sign. $332 fine and 3 points :wub:
could always do what they did on some nissan patrols and thats to add a small power booster to the clutch master cyl making it very light
Rant,
So did you stop? Should be fairly straight forward to fight, especially if you've got a good driving record.
I've heard the argument used in court before about throwing a coin up in the air - the point where it hits the top might not be considered 'stopping', but it is.
Like I told you last night Brendan, Nismo Super Coppermix. You won't get any lighter
CORRECT.
and I can vouch for that 1st hand.
I found the Twin Plate Super Copper Mix had a lighter pedal than the stock 34 GTR clutch......but would bite twice as much
the even funnier thing dion, is how did you find it???? you moving into a jdm supercar purchase..lol
that is some funny stuff, notice the questions about the item too..hahaha
random morning photos to liven things up from a car show in canada
hmm ... wonder what the car was. Nice blue color, possibly aftermarket seats .. hate it when people drape stuff from the rear-view mirror though - or worse (as in that pic) put one of those huggge mirrors and double-sided tape it over the factory one ...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
