For all you IT people
Is it possible to get a SCSI to COM port converter? Or even SCSI to USB?
f**king new server that came in doesn't have a SCSI port and I don't have time to order a SCSI card...
Need it for a bullshit tape drive.
Nope. Not a chance. (I wish - it'd be much cheaper)
Are you after a std 50 pin card or something that needs 68 pin lvd?
-D
  • Replies 14.2k
I can imagine you'd have a number of issues with a USB SCSI converter - both in terms of performance (depending, USB2 will max out at between 30-60MB/s) , and in all likelihood the tape drive will require LVD SCSI (most tape drives do) - which I don't think you're going to find a USB SCSI converter supporting (or at least at a reasonable cost)
What sort of server is it? Reasonably recent? PCI/PCI-X/PCIe?
And yeah - Plain ol' SCSI is just about dead really - SAS (Serial Attached SCSI) is pretty much what everything server-grade comes with these days.
Brand new Dell - PCIe compatible from the top of my head.
I might have to shop around for a card...
Ring ServiceSA brother. They'll have all the information.
yep, motor reg are the guys to call. i have access to TRUMPS at work, but its the "lite" version and unfortunately is read only, and does not show demerit... so dont even ask me to sort out ur demerit points :)
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
