Try outlaw speed shop in the city or main north road Nigel!
p.s. Andrew: http://www.skylinesaustralia.com/forums/19...ls-t312968.html
I can not put in words how f**king sick these would look on your 35 man!!!
  • Replies 14.2k
does anyone know where the heck i can get some of these style clamps from today?
they are called "constant tension" , "preformed" or spring band clamps"
from my understanding, they are a factory-only style clamp, and are rarely sold aftermarket.
Tridon make them, as do a few other smaller brands.
need some 23 and 25mm ones TODAY, and have already tried the following:
sprints
repco
supercheap
universal fastners
motor traders
pirtek
enzed
CBC
any other suggestions?
http://www.smartbuild.com.au/business-list...es/wingfield/sa
Give them guys a buzz see if they got it.
Ive only ever heard that from you. Been running gates belt for over a year and never noticed any difference in noise.
-D
the only time you should really hear a timing belt is when its on too tight and it'll make a buzzing or humming sound.
Nah mate don't do anything for me .... plus I am a bit in love with my LMGT4 copies :)
Whats it going in? sell me the head cheap so I can build a RB30DET for my drift car :)
I am building up a RB27 - RB25 Block with 26 Crank, Rods with over-sized Pistons, along with having Pon/Pro Cams and porting on the head. So the head isn't for sale, but you are welcome to buy the cam covers or swap for RB26 cam covers plus cash your way.
i suspect thatll be a no go Wayne, Abe searched for ages to find that 25 head!
Indeed I did, found via Facebook, thanks to Dion for pointing it out for me, and I picked it up for a decent price too, $350.
sprints
repco
supercheap
universal fastners
motor traders
pirtek
enzed
CBC
I wouldn't put those on my car, fact is when i replace the hoses they go in the junk box
the custom one on my 3lt is a dayco / gates generic one and its hummed from day dot. Its installed correctly as well (using two tensioners to get the correct spec) so it may be a luck of the draw.
FWIW i wouldnt use a trust / gates painted belt either as they have no stretch on the coating and go tight as the motor warms up.
Std nissan parts at all times, unless there's a reason (ie like dark mentioned with the water pump elongated hole bs)
so abe do i get to take the valve covers to use for carbon fibre molds? you can have them back unscathed , timing covers too???? intake plenum ???
let me know if you want help porting and polishing the head, gasket matching the ports ? done a few in my day..lol
crack test with tracer dye... the head before doing anything to it
and gates belts rock, they used to make them down the road from me in USA, gates batteries(optima as well)
Shit yeah!
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
