August 1st 2010,
anyone from here heading out to the motorkana event held at Monarto? I'm going to goto that and have that as my 'skid fix' rather then entering a drift prac and I'll hold off drift prac untill september
  • Replies 14.2k
Just tighten it right up man? I got a hydro so I'm set.
lol. did that. still useless.
id rather shoot some shit. shame thats all members only.
Edited by scandyflick
It's only $45 for the first year - subsequent years are only $30. You get 10% discount at places like Main North Nissan, Willall Racing, Auto Perfection, ISC etc etc .... tell me any year you WOULDN'T spend close to $300 between all our sponsors, and I will call you a liar :banana: .... then to top it all off we have plenty of member only events (or events offered to members only then filled up with extras only if we need them), club-only displays at car shows, club-only dyno days (of which one is coming up start of September - and it will be CHEAP for members - in fact more than $30 cheaper than a normal dyno run on its own), members Xmas dinner (which at this stage seems like it will be free for members), then add in that through us you can get your L2S Cams license for $100 a year .... membership certainly has its privileges.
Just come out for lols man. I'll be useless but I'm just going out there to bust skids.
I took the skyline out once, using 1st gear all day aint that fun after a while.
not entirely correct but mostly
non members will be allowed to attend and participate but members get a 2 week preference in notification and pay $10 less than non members
ill see if i can find the thread that followed the development of the car. pretty interesting read.
found it.
its a pretty epic read, 64 pages, but yeah, shits awesome. car was purchased as a one make series race car, bunch of shit happens, dude gets bored and starts tinkering, and the result is awesome.
and just to show how long its been since ive read that thread, theyre now racing a genesis. rad.
Trouble is that installing headers on a V35 is a $1,000 labour job as it is one of the biggest pita jobs and takes 8-10 hours .... unless you drop the motor of course .... which I will have to do when I fit decent pistons etc sometime down the track. They are on the list :banana:
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
