  • Replies 14.2k
More chance of hitting the big inside ripple strips at Mallala and rolling it than rolling it at Tailem. I've had airtime into turn one before and its pretty exciting that's for sure :D
I must admit, I havn't thrown myself into turn 1 nearly as hard as I should have first time out, guess thats a good thing lol. Hmmm The drop off at Tailem Bend worries the heck outta me. Not saying I won't go out there, because I will - Just feel alot more safer at Lala'
Next time I'm heading out will be september 25th I think. Hopefully you, Craig & Mitch are out then although I'm hanging for it and wish I could go out sooner haha
Luke - Chuck up a few pictures of your cage man :D.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
