  • Replies 14.2k
When did Jack Baker move to Mile End?
f**k.
Is there any other decent tyre places in the CBD?
About 9 months ago.. and they will drop you back into the CBD if need be :D
Also, anyone respond to this:
Any more updates if non members are welcome to the SAU dyno day?
Also, where is it being held?
Thanks!
Lee
Yes, It is open to Non-Members now, you will see it at the top of the main SA Section. It is being held at Willall.
or
As Damo just linked.
Yeah they said the landlord in the city store was getting quite greedy.
yup. the amount they were paying basically tripled over night.
was the landlord chinese because MSY is in there now
from memory... yes.
searched my ring off for the pic of those asian people in a cupboard saying "SUPPLIES!" as the picture would have been mildy relevant to the above discussion. Not so funny when you type it out huh.
if anyone sees a white Ford BA falcon wagon on fire somewhere, don't panic, its just me venting 4 years of anger, discomfort and dissapointment. I'm hoping for a FnF type explosion due to the 140L LPG tanks
new Subaru Forester arrives next tuesday :D
new Subaru Forester arrives next tuesday :huh:
can i help? im quite efficient at destroying things.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
