and that sir, is a debate that could take a long long time to resolve (not saying rudd isnt a disappointment, totally is - gillard woulda been better)
personally, i think costello is more to thank for the improvements than howard, much is the shame howard didnt step aside for him but thems the breaks
and i dont think the democrats had any real pull as a major power, but it was better tho when they had the balance of power in the senate - id certainly prefer them to have the balance of power than barney joyce or family first... (even tho barney is good for some laughs now and again)
-D
Much agree I has!
  • Replies 14.2k
i just found this on ebay
Nissan Skyline R32/33 GTR or similar Intercooler
what is similar :D
http://cgi.ebay.com.au/Nissan-Skyline-R32-...=item3c8f4cecbd
have a look it has trust on the front lol,
the m-spec, RSPL and the VSPL never had trust sprayed on the front when i sold them at Ab
just finished reading this interesting piece on rob lucas' site
http://www.roblucas.com.au/news/default.as...icle&ID=172
goes in about how the govt intimidates people, spins media and has a couple of repeat bullies working in the ministry (foley and conlon)
good read, tho naturally coming from the opposition theres bound to be bias
-D
personally i think political parties should be held to election promises, and their pay should be at risk if they dont meet them.....
that could help keep a bit of honesty in the system.
elections are always an interesting time.... you can go with the devil you know, or empty promises. Its a pitty there is no such thing as the labor party anymore..... just the liberals, and the slightly less liberals
well said, do you notice today theyve trotted out ranns wife saying she trusts him.... rather convenient timing.... only now coming out to talk about it (while being stage managed by ranns media advisor jill bottrill - in a government office) rather than 2-3 months ago when the allegations first surfaced....
spin spin spin!!!
-D
Guest
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
