Hey guys and girls,
I have recently started shopping for an R34 GTR.
I was originally looking for a close to stock example, however I have been offered one which 1 year ago, apparently had a complete engine rebuild with forged pistons, racing valve springs - etc.
Anyway, the owner has not been able to provide me any specifics as to what was actually done as they 'do not know much about cars' and no receipts (as of yet) are available for the work done, just that someone called 'rick shaw' (anyone heard of him / them?) did the rebuild because the owner had further plans for the car - power wise.
However, my worry is - for all I know the car could have had a blown engine? or maybe none of the work was done at all and the internals are still stock? or maybe if work was done - it wasnt done properly? As with any used car, I'd have to get it checked thoroughly before purchasing. But is it even worth the risk!?
What are your thoughts / advice in regards to this? Is this a car you would just potentially walk away from buying? Has anyone here been in the same boat or had any similar experiences? If so, please share your thoughts and advice!
I'm a complete n00b when it comes to R34 GTR's in general. I previously had an R33 GTR and have spent most of my life obsessed with them - so I knew my car inside out, i could pull stuff apart, knew what to expect with wear and tear, costs involved - etc without too much worrying. But is there anything in general (especially given the age of the cars now) that I should look out for with the R34 GTR?
Cheers!
Chris.
Edited by KR4-GTR
I've heard of him, if its the one i'm thinking he specialises in rotary's I thought and has quite a good reputation. Not too sure though if he does anything else.
Try having a search on Ausrotary or:
Ric Shaw Rotary
35 Parramatta Rd, Five Dock, NSW 2046
ph: (02) 97167690, (02) 97985713
Edited by Scottydoo
Rick Shaw Racing are a big name with rotors. That said, I dont know what they're like with GTRs.
The easiest thing you can do is, call them up and ask them about whether they did the work or not.
And there's nothing wrong with buying a rebuilt car as long as the work was done right from the start.
Good luck with it all mate. There's so many GTR's out there for sale that you should go and look for as many samples as you can before you make the big decision.
Thanks for the info guys, thats a great start and heaps of help! ;)
I will be looking at quite a few examples - i promise! it took me 3 years to find my old gtr, i'm a pretty fussy person - especially when it comes to my cars.
With the market how it is at present, its great to be the buyer - as you have quite a few to choose from, however on the flip side - it does suck to be selling.
Cheers again!
Edited by KR4-GTR
Hey guys,
I've noticed that SOME of the R34 GTR's appear to have a bit of rust around the brake light on the boot lid. Another area to check appears to be around the spoiler.
Are there any other obvious areas on an R34 GTR which are known to possibly have rust?
Or are there any other flaws causing common faults which should be checked?
Cheers!
Edited by KR4-GTR
^^^^ they're common rust spots and easily attended to.
Steve at Just Jap recommends that the VIN# be traced to see if the car's background stems from Hokkaido (where the roads are salted) and then scrutiny of rust elsewhere needs to be super-vigilant
I have to say I always get wary of people who get hazy when mechanical issues are mentioned - "I'm not a mechanic, but..."
There are a LOT of supposedly low-km cars getting around in Sydney that have had the kms brutally wound back. It's got to the point where I joke with my guys in Japan whenever we see grade 4 R34 GT-Rs with 180,000km going through auctions being hotly bidded on, that "that one's going to Sydney"...
Because I'm intrigued by what you've just said > eclectic because of cross-referencing from PI > and now a sleuth,
my questions are...
If the Yakuza are behind the bankrolling of auction houses in Japan, would there not be some 'phantom-bidding' at several items at auction just because these cars are going overseas?
If so, is it legal or illegal to carry out this practice in Japan?
Are they the people responsible to fudging odometer readings?
Do they have an active interest in www.skylinesaustralia.com or EVO forums for that matter (yes, incl Indonesia, UK, Thailand etc) to check on market demands & prices?
Because of commission rates, it would be in their interests to keep prices inflated would it not?
I don't mind that these Qs are answered off-air.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
