Righto,
I'm expecting a few varying opinions on this but what is the best way to run in a new engine. I've just had mine rebuilt and am about to run her in. The engine is cranking over and is already fully lubed so i don't need any info on that.
Cheers!
https://www.sau.com.au/forums/topic/29184-running-in-a-newrebuilt-engine/
yeah, i bought running in oil - full mineral that's only good for 500 kms. used a special bottle thingo and an air-compressor and pumped oil up through the galleries so it was fully lubed before it started.
You have any suggestions for running it in Sydneykid? ie, nurse it, flog it, vary rpm, long constant rpm drives, stop start work, low speed/high gear, hill climbs?
In my experience i have been told to give the engine some good load at low to medium RPM to help with bedding the rings in, obviously high RPM is bad as is high boost. Mineral oil is advisable for the first 1000k and then it's time to go nuts :crazy: This information was given to me when i rebuilt my first engine about 12 years ago by a family friend who was a touring car mechanic and it worked for me.:rofl:
Run low boost, bring it on load, dont rev it off its t!ts, stop start driving, varying the revs alot (city traffic driving is good) dont let the car idle too much, dont do freeway running in, drive up a mountain road, change running in oil @ 500kms, then service @ 500km intervals till 2k.
Rev the tits off it! Well, kinda. Have a read of this article. It makes sense, and I think I'd like to do it to my engine come rebuild time. But the guys at Bel Performance got really upset at Tony just for driving his rebuilt car sedately around the car park, and it was enough to make me think twice about the procedure.
I dunno, after reading it again it still makes sense. I think I'd do it. If you try it, let us all know how it goes.
Hopefully I won't need a rebuild for quite awhile. The engine's done >100k km and there's not even any blow-by in the oil catch can lines after 1000km from when it was installed. I think the only things that'll make me need one are a failed ringland or spun big end bearing.
[disclaimer: I'm not responsible if it kills your engine! :) All I can say is that I think I would do it myself]
Edit: when I broke in the engine on my new motorcycle 2 years ago, I couldn't resist the temptation to open it up every now and then within the break-in period. It didn't do anything strange, like no weird losses of power or overheating, and no weird noises. So I'm pretty sure it would have been ok to follow the above procedure, if I knew about it at the time.
Hey there.
I beleive the best way to run an engine in is high load, low revs. Load pushes the rings outwards, giving good bedding conditions.
Revs is what ruins new engines, not load.
BASS OUT
Bass Junky:- Cheers dude. I think that's what will be done.
HIPSI - Yep, forgies are in and swinging. Sounds great. In my opinion, impossible to hear "piston slap". Love it.
JimX - No offense dude, but i never thought rev'n the tits of it was ever an option. Boost can't be great for a new engine as RSN11Z said.
I think my engine will see some mild work, low throttle hold in gear (to about 4.5 - 5K) acceleration, high load/low revs.
All I have to say is it's sweet to have it back. Thanks everyone for their input.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
