hmm first photo in the thread I linked.
And if you think its hard to get parts for a private import, try getting something thru Nissan Aus! 6-8 weeks for everything I've needed so far :(
So that was you passing by huh!
ahhh so dats your car.. nice to see you round ed... sorry couldnt wave.. too much traffic.. almost had an accident trying to look thru your tint to see who was driving.. hahahah i saw you way back before the windsor rd bridge and was trying to catch up but the damn traffic was crawling..
ahhh so dats your car.. nice to see you round ed... sorry couldnt wave.. too much traffic.. almost had an accident trying to look thru your tint to see who was driving.. hahahah i saw you way back before the windsor rd bridge and was trying to catch up but the damn traffic was crawling.. will be around there same time tomorrow after i finish work...
what! tel$tra blocks HGE Consulting? I knew the government was working against my business!  :)
how on earth did they decide to block my little site? wierd
Pay me One million dollars and I wiil fix it :)
lol, telstra doesnt block it but Teletech does.. teletech practicly blocks the internet
hahaha thanx gizmo but that link is proxied to us teletech-ers
:bahaha::)
Im so glad I dont work there anymore I have only found one website I havent got access at the moment. and thats only ebaumsworld.com :)
where do you live?
I'm around that area same time mon-fri :freak:
