round midnight last night on church st parra spotted a white 33 mesh wheels
got a nod of approval.
today at 11:30, a black s1.5 33 on marsden rd tailgating another car
and also on penno rd a winered s2 33 plate was black, said DAM***
Nah...cause they did a crap job cleaning my wheels !... !!! :rofl:
and stop whoring in the spotted thread ! :P
i'm sure it wasn't their fault! ;)
spotted WLD33T parked in the north rocks area today.... it had a white bonnet!!!! and unsprayed front bar... is she recovering from an accident? ;)
i'm sure it wasn't their fault! :D
spotted WLD33T parked in the north rocks area today.... it had a white bonnet!!!! and unsprayed front bar... is she recovering from an accident? :D
saw the same car today too
and also spooted
black GTST WKD25T
was up in sydney the wed, thur and fri last week, didnt see as many skylines as i thought, spotted a black r32 at a servo in crows nest, and a wine red 33 with the plates GTSSKY pulling into a beach carpark while i was waiting for a friend to finish work, also had a bloke in a silver 33 pull me over in crows nest to ask me if i knew a good mechanic in the area.
Hi all! That would have been me on penno rd with the DAM plates :( Woohoo! Sorry.. just didn't think anyone would take notice of my stocker r33.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
