Yesterday there was a skyline at my school out on the oval, it belonged to one of the council? people doing work on the school.
White, Series 2 R33 gts25t. looked stock except for the exhaust and rims.
i think the plates were AVS 500
Penrith area
Spotted a nice white/pearl R34 GTT on M4 today ....gave a nice nod and waived....plates were ARR54L...
That was stolen last night. One day after it was purchased:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=69032
spotted: maroon r33 gtst on george street
had a friendly chat and was offered a red light grand prix (which i refused of course)
anyways, nice car... tho, why did u turn on your hazards after you sped off?
hahahah :)
its a sign (friendly I hope) saying that he "beat you".....
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
