Sean you d%^khead, still have your car do we?? wot happened to selling it eh
I was going to sell it but i love it to much, I would love more power tho! :D
Im getting a bike at the end of the year so i will keep the R32 for a while yet. Next time you come into work you have to give me a tour of your car. Ive heard it has some balls!!
oi..your HCR320 aren't you!!!
your such a snob :(
You pulled up next to me a few weeks ago and when i looked over you looked away...I mean..seriously...WHO DOES THAT!????? :D
I see you heaps in north sydney...I'm around in a white r33
hahaha sorry bout dat!!! i mustve been still asleep or something that morning...i normally give at least a nod to a fellow skyliner...sorry :confused:
i really mustve had an off morning actually cos i my fav part of the drive to work is turning down Berry St to see how many ppl i can scare the shit out of wit my BOV as i floor it just before i turn into my carpark!!!
yeah i work in north sydney and i've seen your '33 around a bit too...nice ride
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
