DHC - Castle Towers piazza carpark last night.
was with my mates when i saw it, i swear.. that car just gets hotter and hotter every time i see it.
Yeah i seen your car parked at York street on Fri night at 8:00 pm and i lloked around to see if you were there..you took a parking ticket till 10:00 pm..
Seen ECL too on Walker street Nth sydney in his white 34 at 12:30 pm
hahaha i know eh...
maybe next time you'll spot me! haha..yeah my mates and i were goin off..such a nice car.  :(  :thumbsup:  :thumbsup:
haha if yours was the blue 32 with plates NUT-532 then yeah I spotted ya...
just didnt know it was someone from the forums... :D
NICE colour......its not stock eh ?
and R34NOS...yeah that was me....but it would have been thursday night ;)
just didnt know it was someone from the forums... :(
and R34NOS...yeah that was me....but it would have been thursday night :thumbsup:
ahaha nah unfortunately not..
but i saw that one too, forgot the number plates. very nice though.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
