i spotted a shit slow ass  s13 on the way back on the old pacific...going so slow we drive behind him for a while and decide to over take...
man man i granny is born every f**cken day..heheheh
lol that was me, im a real bad driver, glad to let you guys through
shame about th ticket
:crazy:
*** i wish i had a shotgun to kill him breaked in front of him...i think he wanted  to car jack me or he was pissed off coz i didn't race him...and i lost control coz of him and hit the divider and went in other lane missed two oncoming then hit the divider again and came back in my lane....GRRRRRRRRR he is dead
That happened to me once... it was raining and wet and i spun out and ended up the otherside of the road over the divider. Lucky it was at nite hardly and cars.
Rear coil overs got repalced with much nicer shocks and springs. ~$800.
Manu check your exhaust system as it may have got hit up over the divider, I know my one went up and got knocked up, though its still ok, no leaks or anything.
ain that the truth when you up for some cans mate
when you have some time you should pop round, we can enjoy one (at a time) and play some stick. Your still working? if yes perhaps friday night?
I will have to check with the minister of entertainment and finance!
yea mate still working in between drinks
possibly next friday as im in tas this week getting plastered!!!
and ill have my car back next week so we can discus who has the bigest wang
lol
Done, we might have a get together with the old team track day. I will send some PM's
mate..dirft shit ..i like it ..but knowing that u r organizing it..f**k that.. i never said i am fast or i can beat ya.. it just we were behind u . u were going slow..we like to go abit faster, so we overtake ya that doesnt mean that we were drive like a asshole. just dont like it when u see a fellow got pull over by the copper and u laught at it...f**k maybe i watch u drifting one day and i hope u crash..and make sure i roll on the floor laughing...
yeah it got scratches underneath....i am taking to the Pedder suspension and they'll have a look ..i'll see how it goes...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
