you're gonna be driving a lancer ?
LMAO :D
Evo VIII is faster around Tskuba than a R33 GTR, both in stock trim :D
Either way, driving a lancer has to be better than driving a mazda 121 :lol: :lol: :lol:
So ?
I can still pay you out tho :D
And who said my car is stock?
Dont worry, im 'upgrading' also
haha, lancer might not be stock either :) lol, this is a stupid discussion anyway :D
What you upgrading to?? R34?
Edited by TommO
spotted a red 33 on corner of showground and windsor rd.. i waved.. the chick driving was a lil confused and only half waved!! :)
also spotted a silver 32 gtr... plates GTR something... beeped and got a wave in return.. this was near eastern creek! :wavey:
also spotted some nice lines at ec ;) DIMZILA (sp?) stands out... very nice car dude!!!!! sounded awesome! :)
also spotted brett and adrian causing trouble :)
Weirdest thing yesterday; thought I saw my own car driving around in my neighbourhood! White R34 GTT with Impuls....
Differences:
* Car was stock except for exhaust
* Car was riding at normal height
* Rear wheels kinda skinny :)
* It had a sexy sun-roof
Spotted outside of Col Crawford BMW... if you're on here mate, let us know we'll meet up sometime.
Also, another R34 GTT with black tail-light surrounds, always spot you around the Balgowlah and Dee Why area... you on here too?
spotted ?REL15H? i think that's b-man.. saw u at the last sec so i just barely got half a wave in lol (i was the blue r32 gtr on mowbray rd)
spotted a nice looking white r34 gtr plates "IFONLY" on the M4 on my to EC.. didnt even bother to look even tho they weren't going fast..
sic kents <_<
