Spotted the MARSSS mobile on ryde bridge the other night and also massiv on same brigde boosting it last night!, hey guys i'm the one working on the brigde at night, going past again give us a honk.
Hahaha! were you the guy with the paddle??? i was doing 60 and i got a dirty look... soi slowed down to 55... :)
haha nah i ain't no traffic controller, i actually work for a living. i was pulling making a hole in the road where all the trucks were parked, its funny cause my mate asks how can i tell when a skyline goes past cause everytime one does i look i said you can hear them coming.
BTW nice ride too MARSSS
Thanx champ!!!
Spotted white R32 GTR (AUN80S) yesterday - followed it down the F3, onto Wyong Rd across Tuggerah..... very nice!
Go the coasties!!! :D
hi tinks
spotted you back, v neat white 33 gtst, if you waved i carnt see nething through those side tints
go the white skylines!!! ;D
adam!!! where is ryde bridge and how long you there for?!?! *tries to plan driveby* ;)
skyline thrash ryde bridge tonight :)
Spotted a grey 33 near chatty thisavo, got a dirty look from the old fella driving it
spotted a 4 door 33 in roseberry (fark they look ugly)
White R33 gtst today that looked almost like Masses car except with stockies, had the stealth wing and all.
We were both on Kent st and he was in front and he gave me the thumbs up as I went pass...anyways I flashed my hazards as I drove past !
Anyways nice clean 33 !!!!
adam!!! where is ryde bridge and how long you there for?!?! *tries to plan driveby* :dry:
Gidday Mona, hows the car going?
Be there till end of next week probably, yeah that would be a sight to see all the SAU regulars doin a drive by!!
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
