forgot yesturdays spottings!
spotted Anna (coastie) in wahroonga and few mins after another black 33GTSt - waved o both cept I was in the mrs 323.....
and then saw a silver 34GTt on galston road
and then just then a silver 4 door 34 - waved but once again - driving the mrs car and people think im a tool!
Galston road man - hornsby heights! just before somerville Road I think - approx....6 20/30?
Dam, wasn't me then... I was coming back from north shore prestige at balgowlah (pardon spelling) around that time would have been along epping rd in the traffic.
spotted a silver 33 on fox valley road wahroonga, waved but dont think he had time to wave back??.
and i spotted hot boy in dark blue 32 with no wing AGAIN on epping road. who are you and where have you been all my life!!!.
bec my car is black not blue hahaha
Edited by burnsie
bec - wasnt me sorry - i drive a gunmetal grey 33 - your getitng me confused! :no:
sorry.....my bad. CLEARLY i need my eyes checked.
if so.....you mustn't be as HOT as i first thought?!?!
quite often in the mornings on my way to work along Lane Cove Road through North Ryde
aaaaahhh, are you one of those random people i wave to in the mornings??.
do you have a silver 4 door 33 or a maroon 33....??
nope I have a black Honda Accord Euro. Was in a black S15 this morning though
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
