I was the gunmetal grey R33 GTST.. I stuck my head out the window as I turned into the motorway :nyaanyaa:
did u wave to me i have a black 32 with black rims? if not i spotted a gunmetal grey 33 last night he waved i waved
Hahahaha!! :nyaanyaa: whoops!! :D:P
Damn you Smoky *shakes fist* .......... hahahahahahahaha
I had NO idea where I was and was just following stove lights!!! I thought everyone had gone down towards the bridge or something and I was going god knows where!!!
Yep that would have been me :/
Hahahaha!! :wub: sorry Kasey :wub:
spotted a white 33 at Wils fav roundaout in cherrybrook this morning.. at about 7:45am.. also spotted at about 8:30, a silver s2 33 with impuls at the bathurst st/anzac bridge intersection!
:wub:
That was me Mooner :wub:
didn't see you tho
There is a nice midnight blue 32 GTR in Blaxland Lower Blue Mountains....I see the car all the time and would love to chat with the owner....anyone know this car or owner ???
Spotted a white R34 GTT (not sure of where I was) they waved and I think I saw a SAU sticker.
I was in passenger seat of my car :D So dad didn't wave but I did.
Also spotted a black R33 GTST with clear tail lights, nismo stickers and an enlarged skyline "S" above the GT badges. Waved but no look
really?! ms said it was you, then took it back! :huh: what are your plates? SQ11SH? or something?:) we were just coming off anzac bridge and heading up bathurst st... you cross in front of us :P
Yea...
Them's my plates :P
Didn't see you guys... :wave:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
