Someone beeped at me this evening while I was filling up at BP asquith(They have ultimate, be quick!!). Turned around late and spotted a black R32 with a mean sound to it so I think it was Burnsie. :glare:
Also spotted about 11pm a black R32 in the shell around Thornleigh, gave you a beep, and then a maroon R33(stock looking) in Hornsby.
Im abit slow but I spotted a Black R34 on Sunday at Pacific Highway, Chatswood. It zoomed past me with a few toots and I blasted a few back :D
Also a bloke in a Wingless Electric Blue GTT at Homebush crusing with me for abit down that main highway thingo lol.
Cheers Nice to see u blokes
Spotted a light coloured (silver?) R33 scoping out my R34 parked in my Grandmother's driveway late last night near Bankstown Airport.
(not really visible at night from the road I might add, so they must have seen it during the afternoon)
They wisely decided to quickly leave once they realised they'd been spotted.
How do you Sydney people put up with that shit every day?
Shotgun.. seems to work well. Well I never see them after that is all I know lol
Indeed :ermm:
I didnt have one handy at the time, although I did have a star picket handy just in case.
Your granny lives in Bankstown and does not own a gun? She must be part of the 1% which do not hold arms.
No, not exactly in bankstown, but near it.
To me, all parts of Sydney are the same - I wouldnt feel safe parking any of my cars in any suburb.
Where I live, half the time I don't even lock the doors when I go out... the worst crime in the whole area is probably me, washing my car with the hose :ermm:
Personally, I'm just grateful that 4 million people actually choose to live together in one small concentrated area rather than spread out across the country :D
Spotted a white R33 GTS-t with GTR wing and R32 GTR wheels on Gardners Rd.
Why do people put older model wheels on newer model cars??? It just looks wrong... :yes:
:banana:
Possibly Adam? AdamsR33 or whatever he changed his name too..
And you cant blame a poor R33 driver for wanting to harness some of the awesomeness that is an R32 can ya?
:banana:
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
