spotted a silver stag on sunnyholt road last night, rear wing..looked tuff
a black wingless 34 with big wheels
black r33 with big wheels
and a yellow 34 with a black vented bonnet
(oh these were all either sunnyholt road or near b-town tafe)
Spotted wite 34GTR ebd of M4 parramatta rd. rushing like crazy.. and both gave thumbs up! BIV-***
Spotted white 32 driven by a Blonde Girl.. at blacktown carwash.. Richmond Rd. YB-50-FT ...lol cool plates i reckon.
Spotted yellow 34 M4 city bound this morning. wingless.
Me too!
Also spotted JET34R (black R34 GTt) around 5.15pm today on Seven Hills Road in Baulkham Hills, then a white R32 GT-R wearing black wheels with red outer lip coming off the M2 and onto Abbott Road in Seven Hills around 7.20pm.
That yellow R34 lives at kellyville i think, always boosting everytime when i see it :P
Spotted a white R34 GT with CF bonnet and a huge wing tonight in Glenwood. red ps
Just spotted Kel in the 350 followed by Duncan in the Race Car :(
that was Craved and I waving from the ute :)
Haha we were wondering who that was beeping like crazy at us!
Sorry for not waving back.
We were on our way home from State Champs at Eastern Creek via UAS.
John is a champ for staying open so we could pick up some stuff to fix a little overheating issue.
spotted a black 34 on old windsor road tonight. He pulled up next to me, said "nice car, is it manual?" i said "thanks, yes" then the lights went green and i got stuck behind an old lady in a merc!! Not sure if he's on here but sorry for not talking to you properly, didn't mean to sound rude!
saw you the other day on windsor rd, i was in the silver forester :)
Spotted a purple R33 S2 this arvo on windsor rd going towards seven hills, had sticks on the front windshield.
haha yeah Duncan had that "oh hey! but who are you?" look on his face :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
