Guest barbie iz a bitch
right you are mona! cuz mz barbie chick keeps raving on about what a cool place teletech is to hang out i decided to check it out for myself!!!!
simply just pointing out how many ppl suprisingly seem to hang out at my work!
its shit house!!! tay had a party last nite n so i'm very much feelin like rat s***!!!!!
Oh? u feel sh*t???? you went to bed early.. I feel like iv been hit by about 20 trucks and like i have drank a glass of poisen.. :throwup: I passed out around 6am after I finished those smirnoffs..I cant belive I have to go to work I feel like Im going to die.. :P
Yeah Ed? y didnt flik invite you! how rude!!! :jk: Fliky u know I luv ya chicken!
spotted Messiah! parked in Yale close in north rocks last night!! :P
hey crazy car crash on pennant hills road.. If anyone plans to drive down it today i advise you not... ( unless you feel like coming to my work to give me some sort of hangover-cure pills) At least I had an excuse to be late to work.
:jump:
u suck!!! that y u missed out. i'm talkin 2 hot aussies! green p's, blonde scruffy hair, almost as hot as macca's guy!
very much HEY HOW U DOIN?!?! nice wheels too...
LOL go flik. Just cos I was in training.. Ill go hunt them down..
p.s Im sure they dont beat the maccas guy :D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
