Where is this teletech carpark? i want to hang out there too!  lol
Was wonderin when i'd bump into u mona, since i go to round corner twice a bloody day now. Any black spots i should know about?
Thats twice i've seen you now!!! once turning onto boundary rd from penno rd, and then on bellamy rd!! what are you doing going to round corner? and twice?! what tha!!!!! :D
and as for black spots...the cops sometimes like to hang out the side street after the school crossing lights, plus at the top off the hill...they either hide in cherrybrook rd, or in the trees : but they're not there often! i haven't seen them in ages!
from an outsider reading all this. it seems that ppl need to get out a lil more instead of doin happy laps of this car park.
and i could post that i spotted a shit colour 1987 toyota camry station wagon, with a purple haired old bag driving, and it would still have more relevance than some of the other posts in this thread.
u ppl are funny!
Spotted at Dutton Rally
Black 31 with GTR engine and very loose left front control arms...doing big lockups and drifts all weekend
Black 32 gtst driving sensibly and doing well :D
Blue 33 GTR doing 11.3 in the 400m test (and getting caught by the 31 in the EC circuit sprint rofl)
Red 34 GTR not blowing up this year and cleaning up Class A (skyline class :) )
and in the carpark a red 31 with an rb25, a black 31 with a new rb20 and a 31 with the trusty old rb30.
And a bunch of other stuff like lambos and porkers
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
