Yea i think it had a series two wing
Anyways shortly after that i saw a white r33 gtst pass by, had a series two wing but it had no front bar on it and i didnt see an aftermarket fmic so i think it was stock except for the exhaust.
hehehe... yeap thats right!  he does work there :)  I hear he has bought alot of stuff off you! hehe... i'm just waiting to see it all on his car! :D
Oh!!  and sorry to hear about your baby :D  thats gotta suck :)
u serious? b4 Craved does anything 2 his car i think he should get rid of the black door...nice car but one black door looks sh!t with a blue line...
SPOTTED: dark blue line - ABS 527 i think those were the plates...cant remember now. in my brothers workshop! :)
Yes all true. The Ztt makes 330+rwkw with almost no lag:worship:.......no no bad, i'll win one that's what i'll do! lol ..anyway make sure you get Craved and urself down the Street meet if he isn't workin, we are running the 33 GTS4T. Should suprise A few GTST owners off the line..:burnout:
Hmm... i'm yet to see a ztt!!! Make yours the first! :)
When you running the gts4t?! 330rwkw? thanks for the tip!! i won't be taking you on in a hurry!!!! :D
Hmm... i'm yet to see a ztt!!! Make yours the first! :D
When you running the gts4t?!  330rwkw?  thanks for the tip!!  i won't be taking you on in a hurry!!!! :thumbsup:
It's always good to be different, was also thinking of a GTS4 32,0r 33 with a 2JZ
The 33GTS4T is running today/tonight.
A 2JZ engine? that sounds familiar.... what car does that engine usually sit in?!
hmmm.... taking a camera? i don't think i'll make it out there tonight :thumbsup: at least the weathers holding up! :D
Edit: SUPRA ENGINE????? Is that right? Or am i thinking down the wrong path again?!?! why are you doing an engine conversion like that?!?!
Damn straight you're rooting for the rb26!!!!!!!  or you're out! :thumbsup:
how is it stronger than the rb?  i always wanted the supra!  till it found out what a skyline was, that is! :D
not sure on the technical aspects...but all i know is that it can withstand a bit more power than the rb26....with stock internals...
haha who is going to kick me out ???
you ? :D :jk:
Hrmp!! who cares! its still in a supra! :D
but now that you've said that, that might explain why BOOSTD wants to put the engine into a GTS4!!! Cause you'd be able to pull more power before messing with the internals?
Hell yeah i'll kick you out!!!! I'll leave a foot imprint on your butt, and then own it for good measure! :thumbsup:
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
