I'm thinking of going for aftermarket rims and not being made of money I'm thinking of selling the stockys to help offset the cost and wonder if anyone is interested in them :-
doubleclick image twice for full size image
They're OE 98 R34GTT 17 x7.5 (8 ?) with a 35 offset (I think) 5 x 113/4. whatever, I'll hoy one of and check if anyones seriously interested, there's no gutter rash or dings/scratches on any of them.
I'm just interested in how much they would be worth and if anyone would be actualy interested in buying.
https://www.sau.com.au/forums/topic/291963-eoihow-much/
They are 17x7.5"
Offset is +40
A good price is $250-500 depending on rubber (you'd be lucky to get $500 and thats if the rubber was first class ie:Re01, GSD3 etc..)
In saying that, I have these on my 180 and they look decent enough ;)
Goodluck with the sale.
https://www.sau.com.au/forums/topic/291963-eoihow-much/#findComment-4882342
They are 17x7.5"Offset is +40A good price is $250-500 depending on rubber (you'd be lucky to get $500 and thats if the rubber was first class ie:Re01, GSD3 etc..)
In saying that, I have these on my 180 and they look decent enough :P Goodluck with the sale.
:P Thanks for that, gives me some idea if I go to trade them on the change over, I wouldn't be going up in size so I'd probably be wanting to keep the rubber thats on them and as I ain't into giving stuff away it'll probably be easier to use them in a trade than haggle around at that price, but as you say they look decent enough anyway so I won't be rushin.
:down:
https://www.sau.com.au/forums/topic/291963-eoihow-much/#findComment-4883394
i am about to start looking for a set of these till I can get my 17x9 +20's on, and my budget will be $300 for a set. if that gives you an idea.
Ah -Ha, thanks mate, would you expect rubber with @ $300.00 ? :down:
https://www.sau.com.au/forums/topic/291963-eoihow-much/#findComment-4883527
I got $400 for mine iirc ..had decent non-yumcha rubber on it down to about 50% I think...no gutter rash and centre caps. Just to give you an idea
I regret getting rid of mine .. would be perfect for the track to have dedicated wheels/rubber. Plus the 17s are alloy and much lighter than anything aftermarket you get (unless you get jap forgies)
https://www.sau.com.au/forums/topic/291963-eoihow-much/#findComment-4883748
Yup I know what you mean, I got rid of a set of OE 16s of a 00 WRX and put a set of Starcorp racing 17" boat anchors, stupid me, the OE 16s were infinately better wheels, wieghed next to nothing, better idea to keep the stockys anyway and put them back on if I sell the car and sell the aftermarket ones.
You wouldn't happen to know what the stockys wiegh by any chance ?
https://www.sau.com.au/forums/topic/291963-eoihow-much/#findComment-4884017
Basho, please post the price you are asking or the thread will be closed.
No EOI's.
:) No worries cose it or it could be moved to general disscussion if you want ??
Quote"-
"I'm just interested in how much they would be worth and if anyone would be actualy interested in buying."
https://www.sau.com.au/forums/topic/291963-eoihow-much/#findComment-4884976
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
