I just picked this up as advertised an an "r33 recirc valve" however Im thinking that this isnt what it is. I sort of suspected this when I bought it but it was just a fraction of the $50 that most people charge for one on this site. Can anyone tell me what it is? or if it is possible that I could use this on my 33 gtst?
Edited by Crackfox
https://www.sau.com.au/forums/topic/292461-what-is-this-part/
I am pretty sure that it is a GTR type twin recirc valve and I am currently fitting one of the recirc valves to my skyline, I'm currently installing it and will see how it goes, looking like the only modification needed will be from the different pipe sizes which is an easy fix. Will see how it runs soon
OK so its a GTR bov? not bad for $10 then I guess:p The guy selling it didnt know much about it, he drove an audi and when I asked which model skyline he used to own he said he had never even owned a nissan so I dunno how he obtained it.
I have taken one of the recirc valves off and installed it on my skyline. Is the only difference between the gtst and gtr recirc valves the pipe sizes on the larger end? can anyone confirm this or are is there other changes as well?
Seems to run fine with the new recirc valve, now it makes a funny "pchieww" type noise instead of pshhhhttt at gear changes, the cars responsiveness also seems ever so slightly decreased though it is a very subtle difference which is expected I guess. The cars small backfiring issue and occasionally lumpy idle also appear to be solved.
just get a mirage 1.5 radiator hose and cut it and it will fit to gtr bov and gtst stock plumb back piping :cool:
i posted the part number sum where but cant seem to remember what part number it was
I just connected it by putting a piece of the smaller gtst bov type piping inside the larger gtr rubber piping, and then put a radiator clip thingie on it and joined it as normal. I don't think its leaking but I may test it further just to be sure.
*cough* dodgey *cough*
Why is it dodgey? Its a more secure fit than the stock plumback connection, if any connection does fail on my installation work it wont be this part. Anyway I would rate my work as alot better than the very messy previous atmospheric blow off valve installation.
Well the GTST ones aren't too flash for high boost and they do have a little hole in them that leaks off air a bit. People weld this up and then supposibly its fine for high boost. No idea why it is there from factory, maybe some one else can explain that. Perhaps a safety for a boost spike so it bleeds it off? I believe the GTR ones don't have this hole hence why they hold higher boost fine.
Edited by PM-R33
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
