  • 4 weeks later...
i asked this question like 6months ago i ended up gettin the wires and i still havent installed it
dam motavation
red = key off
yellow = key on
blue = acc or IG2
black = body
brown = brake switch
orange = no use
i hope these are rite
get in there big dog
:D
  • 3 years later...
i just installed this to my car, very good little unit.
dnt worry about that dial on the back... just leave it
red is live, yellow and blue is acc.
brown is handbrake - wont work with this not connected.
black is ground
leave orange out nothing.
Edited by zero'sR32
  • 3 weeks later...
a couple of people have asked me about the english version i have, which was posted here but no longer, if you go to
http://pivotjp.com/download/flame-download-e.html
this is a link to the english website which has all the pivot manuals in pdf form.
whats really funny is i haven't installed it yet and i bought it for $280 5 years ago. sad face....
  • 3 months later...
orange = no use
:blush:
The orange wire is RPM sensor.
Because this timer is a true auto-timer, it senses the amount of time above a certain RPM, and adds time to the count-down accordingly to the way it's been driven.
Having said that it can be set up in manual mode, where it is always set for xx number of seconds to shut-down no matter how it's driven.
B.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
