Same. Straight fit. ONLY problem I had when fitting the whole a/c system into my N1 is the oil cooler and electrics.
N1 doesnt have a/c looms and the oil cooler is mounted in front of the intercooler where your condenser should be going. Other than these, everything else fits perfectly.
Got a series 1 N1 but the parts were taken from a series 2 gtst. Hope that helps
Check the forum I'm sure there's a few wrecking 33s around. Or like you said, you can always check the exact part number.
Unfortunately my wife doesnt like winding down the window + summer is quite hot in Brisbane too you know. Hahaha
On his profile it says 32... Unless he's got another but anyway I'm just stating my experience when I put in the a/c back then. The exact parts I put in were compressor, condenser and heater box.
The compressor is the same but the top hat that the pipes connect to are in a different spot. You would need to change the top hat of the compressor if you did want to use a gtst compressor.
Brandons link is the go James providing the compressors ok.
  • 14 years later...
Hey guys I'm currently in the process of putting ac in a gtr . Getting parts of a r33 gt25t any help or info Will b appreciated jst wondering if condenser is the same for now . Pump is definitely different
It's different, the GT-R has the dryer attached to the front of the condenser. Where as on the GTS/-t it's inside the engine bay, next to the charcoal canister.
I suspect if you changed the lot (dryer, condenser, compressor) it may just all fit (please DYOR).
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
