you could make a display showing which gear it was in for any car, but I wouldn't cut up that 300k display for it ?
maybe make one that goes near the shifter instead or LED/Numeric LED lights that come on hidden in the cluster instead of the old fashion ones ?
just a thought ?????
https://www.sau.com.au/forums/topic/292776-r34-300km-dash/#findComment-4891647
yeah that maybe a way
i just thought someone out there may have done it before
i was thinking it would be a case of swaping the parts in the red out of the old dash in to the new or the blue parts out of the new into the old
https://www.sau.com.au/forums/topic/292776-r34-300km-dash/#findComment-4892834
The question here is WHY? if you put the cluster in without the display who cares. Or do you need to be remined you in D for drive all the time. For all the bother your thinking of going to what is really the point.
I agree, WHY...lol
plus you better have the other gauges that are missing if your car isnt a GTR ? oil pressure etc.
if your a tiptronic then just build a digital readout and hide it in the dash cluster to know the gear, D for drive hell it should be B for boring to drive with a auto...hahahah IMO
https://www.sau.com.au/forums/topic/292776-r34-300km-dash/#findComment-4893608
I'm no expert in this...
Just swap the tacho and speedo sections over...
Just a thought.
that would work a treat , if the curcuit boards and contact points are the same ????? without seeing one in person its hard to say without spending a while looking into the diagrams.
good luck mate
https://www.sau.com.au/forums/topic/292776-r34-300km-dash/#findComment-4895920
good luck mate
I'd "imagine" the tacho part would be the same...
speedo - I have no idea.
https://www.sau.com.au/forums/topic/292776-r34-300km-dash/#findComment-4900609
I saw this a few nights ago on japan yahoo auctions - first time I ever knew they were made:
http://page10.auctions.yahoo.co.jp/jp/auction/m70743547
You could bid on it through importmonster if you really were desperate for it, but don't expect much change (if any at all) out of $1000 by the time it gets to you...
http://www.importmonster.com.au/view?url=h...20nismo%20300km
Edited by R34mac
https://www.sau.com.au/forums/topic/292776-r34-300km-dash/#findComment-4915866
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
