  • Replies 41
  • 1 month later...
Heh. Thats why we have so much trouble getting a pair from Japan! : ) Heard the demand for these in the states was insane too... What would you consider played out? Surley these are a bit out of the price range for vtec yo's to afford?
Cheers.
  • 4 weeks later...
Did you have to roll the guards to fit the 10.5 + 12's? I just ordered a set exactly the same but 9.5 inch + 12. Wonder if i have made the wrong decision! Looks awsome though. Black on bronze TE's... nothing better!
  • 3 months later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
