I'll smash up pics of the front soon. I just bought some JIC coil overs so once I install them I'll take some pics
cool do that!
iv got Teins front and rear for mine, how ever im sticking with 4x114.3 stud pattern as i have a new set of wheels in that size to go on.
can you put pics of the hub you use as well? (when its all in place)
also are you re drilling the holes in the top of the strut tower?
https://www.sau.com.au/forums/topic/293058-true-or-false/#findComment-4900097
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
