wondering if anyone can help me with my dilemma.
my rh front suspension is rogered on my 32, sits 15mm lower than the left. dunno whats caused it, no local suspension shop wants to touch it.
plus its a good excuse to spend money on my car :devil:
i use the car as a daily, was just wondering what everyone thinks whether i should go for coilovers or just change to a bilstein setup. i eventually would like to get into track work a little more. should i bite the bullet and get coilovers, or will bilsteins or the like do for the track?
https://www.sau.com.au/forums/topic/293205-coilovers-or-not/
HSD HR 1600 or there abouts and p1ss easy to install.
been in my 32 sedan for a while now and i love them.
Be prepared to replace bushes and such after a while as stiffer suspension puts more stress on other components.
yeah bushes would be the next step, especially if i dont go with coilovers.
i can get them cheap thru work so thats not a hassle. :devil:
Hey mate,
The question is what is causing it to be 15mm crooked? Which side is low, and is it front and rear?
Have we (WA SUSPENSIONS) had a look at it?
If you want track type work, then coilovers are the way to go for adjustments etc.
Cheers
Brad
Hey mate,
Cheers
Brad
i personally think the springs have been cut, they guy i bought it from liked to cut corners and im still going through the car fixing stuff. and correct me if im wrong, but ive been told that cut springs can loose tension, or something along those lines.
its just front right, everything else appears to be ok. no you guys havent had a look. did speak to you last week bout a price on teins tho.
If only the front right is low, and the back is level, when you level the front, the back may go out.
Cutting springs is a bad idea for many reasons....and yes it could easily cause the car to be crooked.
Happy to take a look at it if you like.
You dont have to go coilovers. Im sure we can find a package/setup to suit your needs and budget.
Cheers
Brad
tein flex $1500 or less
Spring Rate F6k/R6k
http://page9.auctions.yahoo.co.jp/jp/auction/k115291818
or tein street $1200 or less
Spring Rate F4k/R4k
http://page9.auctions.yahoo.co.jp/jp/auction/k121383719
if you don't mind buying from japan you can get some good deals on new or 2nd coilovers
ohh very hardcore
OHLINS
F:14K R:12K
http://page2.auctions.yahoo.co.jp/jp/auction/b101855314
Spring Rate F6k/R6k
Spring Rate F4k/R4k
ohh very hardcore
OHLINS
F:14K R:12K
those are for 33, they fit 32?????
Edited by Brad3416
lol epci fail..
lets try that again one second
tein type flex with edfc (in cabin damper adjustment)
$1500 ish
6k/5k spring rate
http://page6.auctions.yahoo.co.jp/jp/auction/f80305276
tein typle flex $1000 ish
6k/5k spring rate
http://page.auctions.yahoo.co.jp/jp/auction/123904730
tein super street $1000 ish
4k/4k spring rate
http://page18.auctions.yahoo.co.jp/jp/auction/w40766583
btw i just listed ruff price of the coilovers plus shipping just to give you an idea about what is out there in the land of the rising sun lol
ps brad i recon those ohlins would be good for pauly car lol :devil:
Edited by Kaido_RR
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
