wondering if anyone can help me with my dilemma.
my rh front suspension is rogered on my 32, sits 15mm lower than the left. dunno whats caused it, no local suspension shop wants to touch it.
plus its a good excuse to spend money on my car :devil:
i use the car as a daily, was just wondering what everyone thinks whether i should go for coilovers or just change to a bilstein setup. i eventually would like to get into track work a little more. should i bite the bullet and get coilovers, or will bilsteins or the like do for the track?
https://www.sau.com.au/forums/topic/293205-coilovers-or-not/
HSD HR 1600 or there abouts and p1ss easy to install.
been in my 32 sedan for a while now and i love them.
Be prepared to replace bushes and such after a while as stiffer suspension puts more stress on other components.
yeah bushes would be the next step, especially if i dont go with coilovers.
i can get them cheap thru work so thats not a hassle. :devil:
Hey mate,
The question is what is causing it to be 15mm crooked? Which side is low, and is it front and rear?
Have we (WA SUSPENSIONS) had a look at it?
If you want track type work, then coilovers are the way to go for adjustments etc.
Cheers
Brad
Hey mate,
Cheers
Brad
i personally think the springs have been cut, they guy i bought it from liked to cut corners and im still going through the car fixing stuff. and correct me if im wrong, but ive been told that cut springs can loose tension, or something along those lines.
its just front right, everything else appears to be ok. no you guys havent had a look. did speak to you last week bout a price on teins tho.
If only the front right is low, and the back is level, when you level the front, the back may go out.
Cutting springs is a bad idea for many reasons....and yes it could easily cause the car to be crooked.
Happy to take a look at it if you like.
You dont have to go coilovers. Im sure we can find a package/setup to suit your needs and budget.
Cheers
Brad
tein flex $1500 or less
Spring Rate F6k/R6k
http://page9.auctions.yahoo.co.jp/jp/auction/k115291818
or tein street $1200 or less
Spring Rate F4k/R4k
http://page9.auctions.yahoo.co.jp/jp/auction/k121383719
if you don't mind buying from japan you can get some good deals on new or 2nd coilovers
ohh very hardcore
OHLINS
F:14K R:12K
http://page2.auctions.yahoo.co.jp/jp/auction/b101855314
Spring Rate F6k/R6k
Spring Rate F4k/R4k
ohh very hardcore
OHLINS
F:14K R:12K
those are for 33, they fit 32?????
Edited by Brad3416
lol epci fail..
lets try that again one second
tein type flex with edfc (in cabin damper adjustment)
$1500 ish
6k/5k spring rate
http://page6.auctions.yahoo.co.jp/jp/auction/f80305276
tein typle flex $1000 ish
6k/5k spring rate
http://page.auctions.yahoo.co.jp/jp/auction/123904730
tein super street $1000 ish
4k/4k spring rate
http://page18.auctions.yahoo.co.jp/jp/auction/w40766583
btw i just listed ruff price of the coilovers plus shipping just to give you an idea about what is out there in the land of the rising sun lol
ps brad i recon those ohlins would be good for pauly car lol :devil:
Edited by Kaido_RR
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
