Well, in a pinch, you could always ring Mike at MV Autos in Adelaide, I'm sure he could post one to you in a few days.
1 Stirling Rd, Blackwood, SA 5051
p: (08) 83700430
Has done quite a few stageas, replaced the shift solenoids (A & B) in mine. I *thought* the replacement rack includes shift solenoids A and B?
next week i may have my old ones out.... i can get them tested and see whats its worth ;)
just upgrading mine, cause i dont think there keeping up with the beefed up box.
Can I ask what kind of work you've done to your box?
I'll be calling Adelaide today to track one down. Yesterday was the 6 month anniversary of owning the car and I couldn't drive it.
rebuilt to stage 2.
so stagea 2 valve body. and clutch packs, basically anything that is replaceable with better stronger parts, has been done, a bit of welding to help it pump the pressure and shift real fast.
standard solenoids might be the thing holding it back from packing a punch :banana:
took it down today though, on of his hoist broke down, so i have to wait till next week.
rebuilt to stage 2.
standard solenoids might be the thing holding it back from packing a punch :(
Might have to check out something like that in the future. Cheers. Let us know how it goes.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
